Hand throttle
Hello
The lever can be made from a 356 SC heat lever or from a 914/heat lever. The 356 part is nearly a perfect fit. The rod and the other small parts can also be homemade yet most parts are still aviable in germany. ( Duknow US )
Grüsse
Grüsse
Like Roland mentionned. I can be home made!
Find a heater lever. You will have to install a ball end on it.
Fabricate a bracket that will hold the rod in the center tunnel
Weld a plate on the gas pedal bellcrank (or what ever it is called).
And finally fabricate the rod.
I've done a couple of rods, and brackets. I still need to do a bit of welding to finish them up.
My intentions are not to sell them, but will post instructions on how i built mine.
I have pics of the OEM setup (removed from a 914-6) that someone had sent me a while back. Also got my hands on the dimension of the parts.
I'll post to the 914 list and to this forum once i'm done
HTH
Marc-Andre Morin
Quebec Canada
70 914-6 conversion 3.0
HTH
Marc-Andre Morin
Quebec Canada
Hi, I think I may still have one for my car that I removed.(Does not work in Right hand drive)
Let me know if you still need one as I will have to go and look for it.
Saint
Saint
