914/914-6 Forum 1969-1976
914-6 convertion
Old Dec 3, 2002 | 05:55 PM
Steve@cms's Avatar
Steve@cms
Post 914-6 convertion
Can anyone give me a complete list on going from a 1.7 to 6. I am looking for everything from soup to nuts. I have the perfect doner car but, I wonder what is the best way to spend the my money.
Old Dec 3, 2002 | 07:33 PM
Bleyseng's Avatar
Bleyseng
Post
<a href="http://www.pelicanparts.com/914/914-6_construction_kit/914-6_construction_kit.htm" target="_blank">http://www.pelicanparts.com/914/914-6_construction_kit/914-6_construction_kit.htm</a>
Old Dec 4, 2002 | 07:53 AM
John D.'s Avatar
John D.
Post
[quote]Originally posted by Steve@cms:
<strong>Can anyone give me a complete list on going from a 1.7 to 6....</strong><hr></blockquote>
Sure - here is a list including the SC front end and the GT Flares I did for my conversion. While I had many of the parts on hand (especially the core engine, 911 suspension, etc. - I tried to assign what the market price would be if I had to purchase them... HTH!!!
Oil System
Misc. Fittings $200
Oil Breater System $52
Oil cooler $250
Oil Filler Neck - Dipstick (modified) $60
Oil Lines $215
Oil tank $450
Oil tank console (filter attach) $125
Thermostat $125
Subtotal
Engine
215 or 225 clutch/flywheel $500
911 Mounts & hardware $72
Accelerator Cable for new linkage $45
Accelerator Linkage Assy $200
Combo Guage $80
Distributor ('78-79 SC) $150
Electrical Adaptor (14 pin male - 928) $18
Engine (3.0 long block) $4,000
Engine Mount for 6 $450
Engine Rebuild (top-end parts only) $890
Engine Sheet Metal $250
Exhaust System-Muffler $200
Fuel Guage $40
Fuel Lines $30
Fuel Pressure Regulator $25
Fuel pump (for Webers) $40
Headers/Heater Boxes $450
Oil Pressure Sender $45
Straightend Shift Rod $60
Tach $110
Weber Throttle Linkage Assy $200
Webers - 40 IDA $750
Wire $10
Subtotal
Suspension - Front (911)
911 Front struts $75
A-Arms $120
Ball Joints $66
Hub (5-bolt) $75
Spacer $60
Spindle $50
T-Bar cap $15
T-Bar cap Adj. Screws $5
Carrera Rotors $90
951 Brembo Brakes - Front $290
Torsion bars $100
Wheel Bearings $23
Subtotal
Suspension - Rear Conversion
175lb Springs $90
5-bolt re-drilled hubs $300
66mm Studs $40
Coil-Overs $150
Rear shocks $225
Trailing arm reinforcements $60
Wheel Bearings $30
Subtotal
Brakes
19mm M/C $100
Brake pads $43
Front Brake Calipers $150
Lines $80
Rear Brake Calipers $250
T-Fitting $5
Subtotal
Body/Chassis
GT Flares $1,495
GT Front Valance $150
GT Reinforcements $120
Wheels (5-Bolt) $900
Subtotal
Total $15,249
Old Dec 10, 2002 | 11:12 AM
Charles Navarro's Avatar
Charles Navarro
Platinum Sponsor
Post
<strong>
Oil System
Misc. Fittings $200
Oil cooler $250
Oil Lines $215
Oil tank $450
Thermostat $125
Subtotal
Engine
Combo Guage $80
Fuel Guage $40
Fuel Lines $30
Tach $110
Wire $10
Subtotal
</strong>
Sure makes the cost of doing a big type 4 correctly much more palatable. :-)
Charles Navarro
LN Engineering
<a href="http://www.LNengineering.com" target="_blank">http://www.LNengineering.com</a>
Aircooled Precision Performance
Old Jan 30, 2003 | 12:17 PM
Clay Perrine's Avatar
Clay Perrine
Rennlist Lifetime Member
Post
"Sure makes the cost of doing a big type 4 correctly much more palatable. :-)"
But you will never get the sound and performance of the /6 out of a /4. The /4 will be pushed to the limit at 2.5L for displacement and HP output. A /6 that will fit in a 914 can be pushed to 800HP and 4.2L. It requires megabucks to get that kind of performance. A 3.0L /6 in a 914 is a perfectly docile daily driver with a lot of grunt when needed. A 2.5L /4 will be a cantankerous beast that will have temprature problems and will require constant tweaking and maintenence.
Hope that helps.
Clay Perrine
Old Jan 30, 2003 | 03:46 PM
kjell's Avatar
kjell
5th Gear
Post
Steve, after spending over $20K and more than 300 hrs building
a 2.4L 914/6 conversion, I would have to conclude
that if you want one (they are great cars!), buy
an original or a conversion someone else built! You
will save alot of time and money.....
