fog lights????
fog lights????
Anyone know if some sort of sealed beam light will fit in early fog lights(the round ones),my reflectors have surface rust and I think they are beyond re-chromeing.Thanks!!!!!!!!!!!!!! <img src="confused.gif" border="0">
Check out <a href="http://www.ponycarstore.com" target="_blank">http://www.ponycarstore.com</a>
Their part number I use is E7ZZ15200R, fog lamp
assembly, 87-93, Clear. (Ford Mustang)
It is a black plastic housing with sealed beam of the same size as the 914. I remove the stock fog light mounting bracket from the steel housing, remove the mount that comes with the Mustang fog lamps, and install the stock mount on to the new Mustang housing. It takes a little fooling around but it works well.
Phil
Phil
