rear targa latch adjustment.....
the rear passenger side latch is a bit loose. it doesn't pull the top down firmly enough to set the seal. drivers side is the same but not as loose. just got done looking through haynes and they only talk about adjusting the front. any suggestions on firming up the back latches?
and the rear targa seal is new.
since it never seems to stop raining here in western mass, i gotta seal the little money pit up and drive in the wet or just stare at it in the garage.
any suggestions are most welcome....
You should see two allen bolts on the top. Loosen them and the little hook things should move side to side. The more one way and the tighter the roof will get. Try that.
Troy
Troy
