911 front crossmember into the 914
7th Gear
I have an aluminum front suspension member that will go in to accommodate a 23mm master cylinder. Anyone out there done this ? Looking for som general guidance. Thanks.
Rennlist Hoonigan
which cost no drachmas
You can fit the 23mm master cylinder with the stock cross member. You have to clearnce the master cyclinder and cross member some, but it can be done. I found it easier to put new brake lines in when I did the new mc rather than rebend the ones in there.
The AL cross member bolts right up. Should go in nice and easy.
Matt
Matt
