914/6 and master cylinders
I have a '76 3.2 conversion track rig, S calipers front w/ 19mm MC, 914/6 rear, Hoosiers etc. The brakes are lacking at the track. Is there a larger MC, or am I looking at 4 pot calipers up front ? This thing is very fast, need more brake to brake later. Thanks.
Jim Naughton
Jim Naughton
RL Technical Advisor
Jim:
"S" calipers are far from ideal for these applications due to their inherent caliper flex and a car like yours with a 3.2 really needs something much bigger for track usage.
Brake choices depend on what diameter wheels you are using, but a 930 brake upgrade works VERY VERY well on these cars.
If you decide on the Brembo's, you'll need the GTP-L's since the larger GTP's require 17" wheels.
Don't forget to install a 23mm MC with ANY of these brake upgrades.
The 23mm MC is an ATE item and fits a multitude of vehicles.
Indeed, any brake upgrade requires struts with the 3.5" mounting hole spacing and that includes "S", SC, or Carrera struts.
