All good things must end
Thought I drop off this pic as it is a good one of the beastie.
Don't get too excited about the blurb on top as I was about the only one in my class.
Well, I dunno. I'd like to but with vacation getting sucked up by the WCC & Parade
(both in Portland in 2006), I may be fresh out. That course at Mather took some gettin' used to.....concrete, asphalt, concrete. I never found the limits on the concrete, but sure as hell did on the asphalt. If I get down there, it'll prolly be at Marina. I have an incar vid of that Mather course iff'n you wanna see it.
JP,
I would love to see the video. I never figured that course out due to the fact that I had a screw in my right rear tire and had 36psi to start the course and 29psi when I finished. Must have picked it up on the access road as it was not in the tire when I set my tire pressure at home before leaving.
I will try to be at Marina as well. Should be a fun summer as it will be my first in the 914. I should have the Boxster sold by then. Although just to make it complicated the Boxster just split its rear window. Argggggggggghh
Rob
Rob
Here's a link to the vid.
It's 32 mb....tough on the dial up guys.
http://s64.yousendit.com/d.aspx?id=2...V0LN6AZ6L88A21
