master cylinder 4 my 914-4?
hi guys
which master cylinder is recomended 4 my 914-4 ?
i want 2 upgrade the rotors and calipers so probebly ill need 2 change my old master cylinder, any idies? brands?
thanks a lot!!!!!!!!!!!!!
Same suggestion ... again:
http://www.pelicanparts.com/techarti...r_cylinder.htm
Buy it here:
http://www.pelicanparts.com/catalog/..._pg2.htm#item7
Buy it here:
You need to keep the combo balanced. Personally I like the stock 17mm M/C with stock 914/4 calipers and better pads. Porterfield R4-S
It's all about the hydaulic advantage and stuff. I can flat spot a 205/50-15 Hoosier but I also have the modulation control to NOT do it. Skidding is bad
