914/914-6 Forum 1969-1976
914 Alignment Question
Old Sep 29, 2025 | 02:14 PM
edfishjr's Avatar
edfishjr
Default 914 Alignment Question
Asking for a friend... stock 1974 914.
If I push the front strut tops in all the way and take out all the rear trailing arm shims, what amount of negative camber is likely to be produced front and rear? Basically, I'm asking how much negative camber adjustment the factory gave the stock car.
Thanks,
Ed Fisher
Old Jan 31, 2026 | 06:14 PM
dr.914's Avatar
dr.914
3rd Gear
the cars sag causing more and more neg camber as the years go by. 0 in the front and 30 minutes neg in the rear is the preferred stock you could probably get 2 degrees MAX
