69 Clutch replacement
The Hoffinator
i would use jack stands, on the nubs that stick out from the spring plates. they are a good place for jack stands, and will not get in your way. ramps seem to get in your way and not leave a whole lot of room to work. I would jack it up a few feet. also removing the bumperettes and the rear license plate section of body work will give more clearence. its only held in by a few allan bolts and is easy to remove.
