IT ARRIVED!!!!!! IM BACK BABY!
The Hoffinator
hehehehe god, im as giddy as a little boy on christmas..
new classic and speed parts light weight crank pully with degrees marked.
Superdave312 (06-14-2020)
There is a C engine for sale on 356talk at the moment, and one listed on the pelican parts forums as well.
Nice engine Harry . Be a real shame to mess it up and get it dirty by putting it in and using it
The Hoffinator
6810-19 cam grind (about 288* duration)
shasta pistons and cylinders, 9.25:1 compression (1720cc big bore kit)
aluminum oil cooler
full flow oil filter
mainly custom by design sump plate with drain plug
classic and speed parts aluminum light weight crank pully (same dia. as stock but much lighter to protect the nose of that crank! also is marked in degrees)
sock late 912 crank ground to 1 under
stock late 912 rods
stock valves, springs etc
stock heads
solex pII 40 split shaft carbs, k&n air cleaners, velocity stacks
stock fly wheel
John Benton, another engine builder who ground the cam, said he recently dynoed an engine he built with a smililar set up and it was making 127hp at the fly wheel.
aluminum oil cooler
stock late 912 rods
stock heads
stock fly wheel
Originally Posted by Fishman
Doug,
Who's the woman in your avatar? Anne Hathaway?
https://rennlist.com/forums/off-topic/193256-the-great-big-anne-hathaway-photo-thread.html
Originally Posted by I love porsche
ohh that is one purty engine, did you have it built?
Nice engine though.
