912E Header & Exhaust Options
Greetings, looking for some gudiance on a good header/exhaust system for a 76 912E...don't want to go with an oem setup as I'm looking for an increase in power and slight sound.....
I've been looking around and it's quite a narrow field of options available and most aren't cheap...
Any help on a great system to to use is appreciated
Thanks in advance
Thanks in advance
The Bursch is a pretty decent piece. Installs easy, and fits well. But there are limited hangers to hold the muffler choice to the chassis. May need to do a small fabrication to have it suit your set up. As for a power adder?.. The gains are negligible, the sound is more authoritative though..
Another option is the Sebring system, which is well-made and boosts performance. It's made of stainless steel, so it lasts long and resists rust.
Or you could go for the Dansk exhaust system. It's more affordable than some others, enhances performance and sound, and is easy to install.
