1967 912 Oil not coming out if rockers pass side?
Ok, either something is clogged for right oil passage. Possible pressure piston stuck (there ars two) .
Testing oil pressure @ sender have 45psi when accelerating.
Side note, right side also not contributing to power (dead until higher reves reached)
Compression 140 after two pumps. Running Compression 72psi.
