912 roll up window size
5th Gear
greetings:
I am in the process of restoring a 1968 912. The car came with both left and right door window frames. However one is brass and the other aluminum.
The window that slides in the brass frame is very loose even after replacing the frame fuzzies. It looks like the window is not wide enough for the frame.
The question I have is; Are there different size windows for the different window frames?
Stax
Stax
