912E Jacking Point
912E Jacking Point
Hi All,
I'm about to put the 912E up on jack stands for a long awaited heavy C-Check (aviation term). Any suggestions for a preferred point to put the jack for the rear pair of stands? I have read the Pelican Brief blog on jacking the 911. However, just wondering if there is an optimum location for doing the same for the 12E ? Suggestions/comments.... Discuss?
DJ
DJ
The perfect fit. This SnapPad RV Leveling Jack Pad is great!! I ordered a set of four this past May to serve my trip. The first thing about this jack pad that stood out was its easy installation process. Besides that, it has very good weatherproof capabilities. It shouldn’t have issues withstanding the effects of harsh winds, a mighty downpour, or even overexposure to pesky sun rays. This jack pad is made from recycled tires. They will decrease vibration and movement as well, thanks to the tight grip of rubber. Moreover, these jack pads are anti-slip and will be useful when you encounter rougher terrains such as rocks or concrete.
