Hot engine sputters and misses
For a 912E. Only after the engine has run, been turned off for a few minutes or so while it is still hot, turning the engine back on causes it to sputter, miss, and almost stall. holding the gas pedal down in neutral brings it out of sputtering, but when pedal is released, it has the same problem at idle. Only when the car is put in gear and driven a few hundred feet or so does the problem stop. Temp gauge never approaches a concerning heat level. Any insight?
