Can you help this guy out? Measurement
From: Winchester, Mass (and Continental Airlines...)
Stephen, or one of you other fellows with intimate and archane knowledge of the Beast, can you help this guy out?
Lomotpk
I'm working on adapter-plate for 930 3.3 transmission and would like to know distance of flywheel friction-surface from transmission flange. With other words, how deep into the bellhousing is it?
Unfortunately, there is a edge around pressure plate that can mess-up measurments so easiest way of measuring would be during the clutch-job when engine is separated from tranny. It's just a matter of measuring distance from flywheel friction surface to transmission-flange alignment area on the engine.
So please, in case you are in the middle of clutch job on your 930 bastard, just take a look and take out your slide calliper.
Here is a link to picture to better explain what i'm looking for:
http://luminasweden.com/temp/questionmark.jpg
You can mail me on project911@luminasweden.com in case you know this distance...i would be VERY grateful!
Lomotpk
