Supercharge my 911 SC 3.2 European spec.?
Cruisin'
Hi,
I’m planning for the upcoming project to supercharge my 911 SC 3.2 European specification and I need your advice and experience how to etc.
The plan today is to use a VEMS ecu with all the necessary sensors (TPS, Exhaust temp, intake temp, crank trigger, 2x knock sensors etc.) together with a single turbo installation, 993 headers and a large intercooler from Turbokraft. The plan is to use 0,5 bar boost and the goal is somewhere around 100 hp increase, so not a monster engine.
The main question is how I should do with the compression, the European engines have 10,3:1 (231 hp) compared to the us engines that have 9,5:1 (207hp). If I use E85 there won’t be any problem but it would be much easier to go with regular fuel (to use only 98 octane fuel). Will this work ok? As I said I will have a good map/tune with VEMS, double knock sensors and a large intercooler so quite low intake temp.
I really appreciate all the tips, tricks and information that I can get!!
If I would like to lower the compression, what is the best way (without digging a huge hole in my wallet…).
I hope that you understand my English, it is not my native language…
And last some pictures of the parts that I have prepared so far.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
http://forums.pelicanparts.com/911-9...ging-forum/?s=
This is the place you want to be. Lots of knowledge and friendly advice.
Best of luck.
Best of luck.
