Questions regarding my '87 Slant
Evening fellas....wanted to get the groups opinion before I kept going. The complete rebuild on my engine has been completed, and I last saw it before it was in the car and it looked awesome. The estimate was 22-25k, and it's coming back at 28k....oh well. Here's the thing, the transmission has never been opened up/worked on, original...it's out and estimate is 4k to rebuild if it needs anything....now, I did not notice anything before it went in for engine, so this is kind of preventative and what the heck while all is out...same for turbo, is the original....I am strongly toying with selling her, 5 kids under 13 and little sympathy and/or caring from the other half, especially on a car that is not driven much and worth well over 100k....I did put on a fab speed exhaust prior to sinking 30k in the car, but have the original to put back on, which another place in town recommended before selling....the original Fuchs went back on too, and I have the 19" HRE's to sell later....my question is should I leave the original transmission and turbo as is, and sell her or should I open it up for any repair if needed? Is it more appealing to a buyer to have one gone over or is the engine that looks as if off showroom floor enough? Thanks in advance guys.....Hal
Sent from my iPad using Rennlist
Hey Bleu,
Hopefully you have before & after pics of the rebuild too. And since I'd love to see (& hear more), I'll chime in,... hoping the dialog (& camaraderie) helps...
My .02 is based on two things you said;... 1)the fact that you want to sell & 2) the fact that the tranny was shifting well before you pulled it all apart.
I'll also assume that you are indeed replacing typical wear items such as clutch, pilot & throw out bearings....
Leave the tranny as is. If you did not notice any grinding between any of the gears, then lets assume your syncro's are all still healthy.
Why throw another $4k when you're already over budget on the engine rebuild ( & if the tranny rebuild is from the same shop, then lets assume they will, once again, be over by another 20%, and thus you're actually looking at $4,800 ).
Make sure the outside of the tranny is spic&span clean, and put er back together. Any good P guy is going to ask for a PPI inspection anyway,... which means they'll drive it too. And if the PPI comes back solid, and it's shifting well for the test drive,... your golden.
Sorry to hear that you're selling.
=Steve
=Steve
Hey Bleu, Hopefully you have before & after pics of the rebuild too. And since I'd love to see (& hear more), I'll chime in,... hoping the dialog (& camaraderie) helps... My .02 is based on two things you said;... 1)the fact that you want to sell & 2) the fact that the tranny was shifting well before you pulled it all apart. I'll also assume that you are indeed replacing typical wear items such as clutch, pilot & throw out bearings.... Leave the tranny as is. If you did not notice any grinding between any of the gears, then lets assume your syncro's are all still healthy. Why throw another $4k when you're already over budget on the engine rebuild ( & if the tranny rebuild is from the same shop, then lets assume they will, once again, be over by another 20%, and thus you're actually looking at $4,800 ). Make sure the outside of the tranny is spic&span clean, and put er back together. Any good P guy is going to ask for a PPI inspection anyway,... which means they'll drive it too. And if the PPI comes back solid, and it's shifting well for the test drive,... your golden. Sorry to hear that you're selling. =Steve
It is the Tampa car from a few years ago...about 2.5...I drove it a bit for a few months, and the PO had stated that the engine would likely need a rebuild in 15-20k miles. I had it checked out here in VA and all was great. Showed it at Classics on the Green, and drove it minimally...the following summer noticed a ticking sound and my guy here suspected something with piston, and found a copper shim was loose...with 82k miles on here, decided to rebuild, hope was to keep for a while...it turns out when he opened the engine up there were other things that could have only worsened without a proper fix, so definitely did the right thing fixing...either for me or the next owner....am still hemming and hawing a little....realize if I do sell I will never be in a position to get another....with it not sounding right, I did not think I could ever sell it with a flaw, so fixed....my wife just got the news on cost of rebuild without the tranny....not a good Friday in the Bernstein household 😁....but I believe it had to be done either way...no pics yet, but when I do I will post....
a 930 however...
Ah, I see, thanks for the info. I wish I could help you out with the purchase, that is an incredible car! I may have sat too long to realize this mark myself. I did it backwards... when I bought my 928 some years ago for almost nothing, I should have got a driver 930 for 30K... because, as we know... a 928 is still worth nothing. a 930 however... ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
I think its definitely reasonable to leave the tranny alone. Regardless of whether you will continue owning it and settle things with the wife, or sell it, the tranny can always be done on its own separately. The fact that everything was onced over on the engine is a great selling point, if you choose to go down that road.
Same goes for the turbo in my opinion.
Good luck my friend!
Cheers
Cheers
I'd leave the tranny and sell it as is. I still wish I had my slant even though I'd be afraid to drive one anymore as they are irreplaceable, there's something to be said about the later cars, (ie997tt) ideal daily drivers etc. I know when I was dropping large $$ into either of my of 930s, it never went over well at home. All 930s will eventually need rebuilds and they typically run around 25k as you know. Great nostalgic cars, expensive to own, no doubt.
Thx fellas, going to put it back in without redoing it, make it a little more cosmetically appearing to match the engine...which looked pretty awesome when I last saw...although for what it cost, it should!
kinda better than when new...when I get back I will post some pics...although having a heck of a time posting from iPad and iPhone lately...
