A leak I cannot explain. Help
I had a fluid leak on the right side of the engine coming down the front side of the oil cooler and onto the heat exchanger. The color of the fluid is RED. My thought right away was R-12 with leak detector that I added years ago. Could not find any sign of Freon leak. With the car sitting over night the red leak continued to spread on the paper on the floor, which made me think the Freon pressure was pushing out the refrigerant oil, but still no evidence of Freon leaking. The right deck lid shock did not appear to be leaking anything. I cleaned up all the residue
I could find disconnected the right deck shock, it still had pressure. Ran the engine for several minutes. No leak. Drove the car and still no leak. I suspect the shock but do not even know what is inside of these things. Is it just gas or gas and hydraulic fluid? Stumped:confused |
Leak followup
Not confused anymore just feel like a dumbshxt. Apparently I over oiled my K&N air filter. Never has happened before. So all is well. Have a laugh on me.:)
Well alright then.....:banghead::rtfm::thumbsup::roflmao: I never knew that air cooled Porsches used ATF (which is all that the "special" K&N filter juice is....just watered down ATF).
Now for sure, none of us here have ever had anything similarly stupid happen to us - none that will be admitted at least. There's only been one instance in my life when I felt like a shumb-dit....fer sure, just one. |
Mark, hopefully my one and only dumbshxt moves. Thanks for the info on ATF for K&Ns. Didn't know that.
Why oil the air filter? sounds it would heavily impede air flow:rolleyes:
Originally Posted by Mistergee
(Post 12960975)
