Fuel lines
Fuel lines
I recently had a fuel line failure. (Rear pump to accumulator) I would like to replace all engine bay fuel lines but, having trouble locating OEM lines or a shop that is able to make them. My car, 1987 930. Thanks! Rob
Rob,
There's a guy in the north east, Len Cummings, that makes new lines and can rebuild yours with the proper hose. Work is top notch but he's somewhat hard to get ahold of. I'm not sure I've ever seen him post here but he's active on Pelican. The address I have for him is: len@autosportengineering.com. You might also check with Shaun Budka at Tru6. He knows Len and lives in the vicinity: Shaun@tru-6.com.
Good luck!
John
Good luck!
John
John,
I called and then emailed Len but, perhaps, as you mentioned he's hard to get a hold of. I will try the other resource.
Thanks!
V/r
Rob
Thanks!
V/r
Rob
