911 Turbo (930) Forum 1975-1989
NO reverse or speedometer
Old Jul 14, 2015 | 05:07 AM
mtnbiker63's Avatar
mtnbiker63
Default NO reverse or speedometer
Does anyone have an idea why my 84 - 930 won't go into reverse and the speedometer does not work now. Everything was working just fine on Saturday. Took the car out for a spin, backed it into my driveway. Then later that day, went to back it into the garage and I could not get it into reverse.
All the way left and up felt right, but it went forward. Then I noticed as I went to turn the car around and pull in forward that the speedometer was not working.
Old Jul 14, 2015 | 10:51 AM
speednme's Avatar
speednme
Could be the bushing on your coupler(under your car...in between your rear seats). You also may want to check on the Pelican forums for answers as well.
Old Jul 15, 2015 | 08:14 PM
mtnbiker63's Avatar
mtnbiker63
Thanks Roy, do you think it took out both things?
Old Jul 16, 2015 | 03:36 PM
speednme's Avatar
speednme
No I don't think so. If you go on Pelican, there are a few guys from MD who are very knowledgeable. Might be beneficial to have someone local look at it.
Old Jul 16, 2015 | 09:41 PM
MUSSBERGER's Avatar
MUSSBERGER
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Yes it may
File Type: jpg
Old Jul 17, 2015 | 05:14 PM
speednme's Avatar
speednme
Originally Posted by MUSSBERGER
Yes it may
If the bushing on the coupler goes bad it should not affect the speedometer in any way....now if one unplugs the wires(as shown in your photo) than it will most certainly affect the speedometer.
Old Jul 17, 2015 | 07:42 PM
MUSSBERGER's Avatar
MUSSBERGER
uninformed gas bag
OP should pull the carpet back ,remove the cover, and have a look. My money would be on a loose shift rod clamp somehow getting together with the speedo wiring.
Old Jul 17, 2015 | 11:22 PM
speednme's Avatar
speednme
Your're probably right on the money...
