ROTOR SIZE LIMIT FOR USE WITH BIG-REDS
Hello guys,
Can I upgrade my front rotors from 322mm to 355mm and to use my current calipers (1995 993 TT) ???
RL Technical Advisor
[quote]Originally posted by Hunter:
<strong>Hello guys,
Thanks</strong><hr></blockquote>
Hunter:
You may use your TT front calipers with the 355 rotors but there is a larger, more effective Brembo caliper made for that application.
This is called the EVO caliper and has larger pistons using the same size pad. Its machined to allow the TT sized pads to wipe the 355mm rotors much more effectively.
<strong>Hello guys,
Hunter:
