Twin Turbo 930's
Twin Turbo 930's
can it be done I have never seen a twin turbo conversion done to a 930 before, what would be needed to do this, I would think that it would cost $$$$ as well.
Rennlist Lifetime Member
Sure lots of guys have done this converson. They aren't that bad really once you have done a a couple. Guys like Steve W. have been doing them long before Proto or any of the other guys. Clay Dopke was also one of the orginal street tuners. This is the conversion we did to my car.
PorschePhD, thanks for that now one more question where can I find some detailed info on how this conversion is done and the over cost's of what it would cost to do.
Thanks josh.
Thanks josh.
Josh,
These builds come in somewhere between 25-30K just for the motor build. Then there is the injection and install. If you were to install a bone stock TT motor the cost for a used one is around 15-20K. Then install. If you wanted you could also use the stock TT Motronic set up, much like a standard 3.6 conversion.
Ian...We didn't have room for anything else It really isn't that bad...Ok maybe not for me
Stephen
Stephen
