911 Turbo (930) Forum 1975-1989
SC cam timing
Old 07-24-2003, 08:36 PM
DV 993tt
DV 993tt's Avatar
Default SC cam timing
Can someone tell me the correct cam timing for SC cams in a '86 911 turbo.
thanks
Old 07-25-2003, 09:24 PM
WERK-I
WERK-I's Avatar
1.4-1.7mm with best results running around 1.4-1.5. You need all the low end grunt you can get!
Dave
85 930 Factory Slant
78 911 SC RoW
Old 10-14-2021, 01:29 AM
rahulsingh
rahulsingh's Avatar
Dave
78 911 SC RoW
Hello Sir,
Sorry to get into this. I am about to do engine rebuild on 83 , 930 turbo .. is (1.4-1.5 )is correct spec for cam timing ?
Old 10-14-2021, 08:50 AM
WERK-I
WERK-I's Avatar
Yes, that spec.is what we used for factory 911 SC Cams in a 930. More importantly, though, is to get the timing on both sides as close to each as possible. Setting the cam timing to 1.4-1.5 mm merely moves the cams to a more advanced state which should provide a little more toque at lower RPM's. It's not a big gain, just a little. Your are safe with 1.4-1.7mm with the factory SC cams.
rahulsingh (10-14-2021)
Old 10-15-2021, 09:26 PM
CGT000
CGT000's Avatar
Hello all. I have a 930 in need of a engine rebuild. Can someone tell me the difference in using SC cams vs 964 cams? My car has a few free flow exhausts, cat bypass and headers.
Thank you in advance for your input.
Quick Reply: SC cam timing
