How to adjust the CO?
First of all what is the CO adjustment? Secondly how do you do this? I am running no cat so the O2 is unplugged. I have heard when you run no cat that you need to adjust the CO to 3. Thanks
andrew
andrew
Andrew,
You do not do this w/o the CO meter that is needed. I am sure some shop has a CO meter & will be glad to set it for you.
A 3.0 setting is good, but with your minor mod (no cat) you are not in desperate need yet. Once you get headers or more mods then 3.0 is a perfect setting.
The adjuster "screw" is right beneath the airbox body and can be reached w/ a hex wrench from above. You push down until it "engages" and then turn. The movement required is MINIMAL which is why a CO machine is necessary. Seek professional help.
