RUF 930 exhaust, any good?
Dear 930 owners
I'm in the process of getting a 930 (or a 964T). Today I looked at and drove a very clean and good -88 example in almost new condition with only 42.000 kilometers (26.000 miles).
It was totally original, except for the RUF 930 exhaust. I really liked the sound, which was still sort of discrete but a bit more full bodied when accelerating. However, on idle, it had a 'clucking' sound. I thought a little bit more from the right pipes than the left ones. I made it sound a little bit like a V8-boat type of sound, and not a spinning flat 6 from Zuffenhausen. Anyone else who has a 930 with RUF exhaust, or are familiar with them, who can help me tell if this is the normal sound for the RUF-exhaust, or if something is wrong?
Also, is there any gain in power with a RUF 930 compared to the original ROW 930 exhaust?
cheers
Christian
911 Carrera -84
cheers
Christian
911 Carrera -84
Christian: I have a Ruf 4-pipe exhaust on my '89 930 3.4. I have stock headers (no cat), though, so there is probably no hp gain of having the Ruf exhaust.
As for sound, it's totally awesome! I don't notice any difference from the left side or the right. As for what I think it sounds like, well, to me, it sounds like a louder, meaner version of the stock 930 rather than a boat. There's nothing like the sound of a flat 6 turbo coming down the road!
Dan
'89 930 3.4
'97 993tt
Dan
'89 930 3.4
'97 993tt
Dan,
This is the 4-pipe RUF system I'm talking about. It sounded great under load. What I am wondering about is during idle. It had sort of a 'clucking' pop-pop-pop-pop... sound which did resamble a V8 a little bit, compared to the more spinning sound of the original exhaust. For sure a bit more aggressive, but not really in my taste.
And I thought it 'clucked' only from one side, but not from the other. However it was hard to determine, I can be mistaking.
Also, there's no cat on the ROW-cars, so my question is if there are any power to be gained with a RUF-system on a ROW 3.3 Turbo?
cheers
Christian
911 Carrera -84
cheers
Christian
911 Carrera -84
Christian: I'm no expert, so this is all just my opinion. At idle I don't get the pop-popping sound you mention. I get that noise when I take my foot off the gas and am decelerating to a stop.
At idle the car sounds somewhat similar to a stock 930 only much more "throat-ier" (and much louder, obviously).
A US 930 hp rating is 282. Take the cat off and basically it is a ROW 930 at 300 hp. I don't think just a 4 pipe muffler will add much/if any hp. New/better/upgraded headers may give you a bit more hp. Clearly they will reduce the RPM level it takes to get boost going.
Another cool by-product of the 4 pipe - my car is set up in such a way that after lifting off higher RPM boost, I will shoot flames out the back. It is much cooler to have flames coming off both sides than just one!! :-)
If you are looking for hp gain, don't bother with just the exhaust. If you are looking for looks and sound, then you should consider it.
Dan
'89 930 3.4
'97 993tt
Dan
'89 930 3.4
'97 993tt
