ignition problem
ignition problem
After the car cut off the last time for no apparent reason, I measured the voltage on the 6 pin CD box connector. At pin #15 the voltage measured 0.1v. I let the car sit for awhile and the voltage eventually jumped back up to 11.9/12v at pin 15.The car then started, then died after a few minutes with a reading of 0.1v at pin #15. Any ideas what the problem is?
I have replaced all of the fuel pump relays.
Rick '78 930
Rick '78 930
