Problem After Installing K27 Turbo when reaching 4000 RPM
Hello there,
This Thing start happening after installing my New K27 Turbo 4 days ago.
Please not that all the following items was installed new 3 months ago and my car was running perfectly:-
Tial 1 Bar WG
Fabspeed " IC, headers, Muffler, Air intake"
Boost Pressure Switch
Relay for Air Flow Sensor Boost Pressure
New Fuel Pumps front & back
Distributor Cape
Ignition cables
Coil Wire
My Car is over boosting now after the new Turbo installation and I think this is what cosign Cut of or Jerking engine after 4000 RPM.
what do you think i have to do, change my 1 Bar WG to .8 or .9 ?
Is there specific procedure to do with the car after installing New k27 turbo ?
any of you have the same combination K27 with one bar spring WG on his car ?
Thanks,
FAHAD
Tial 1 Bar WG
Distributor Cape
Ignition cables
Coil Wire
Thanks,
FAHAD
TT Surgeon
Do you have the K27 + 1 Bar WG + Fabspeed headers and your car running smooth ?
Some one just till me that Fabspeed headers They are typically made undersized (tubes out of heads are 1.50” O.D.) and the pipe off to the wastegate designed does not allow exhaust to bypass the turbocharger properly. This results in too much flow through the turbo, and too much boost.
But i'm still not sure, I think i'm going to change my WG spring to .7 or .8 Bar what do you think ???
FAHAD
FAHAD
Yes, I have all of the above except an Andial IC and an Andial modified k27
Car runs great. The headers are the same design as BB, ghl and others. It's not the headers or else mine would do it too.
