AFR graph help with adj WUR
Gents i am currently adjusting my WUR . I have adjusted the WUR by hitting the full throttle enrichment insert in by 2mm from original setting. (it is now 4mm below flush)My car at its richest was 10AFR. Can anyone advise how much this insert is tapped in until a mid 11 AFR is gained. Can anyone share a graph as mine looks all over the place. Could someone have a look at the attached graph and advise if this is too rich or too lean. The graph starts in 1st gear with a 2nd and 3 rd gear change throttle wide open. The AFR unit is a LM-1.
Car is running 0.9 bar boost, 3LDZ, all standard apart from K@N's.
TIM
TIM
