CV Joint Installation Need Help
When I removed the engine and tranny I found the Circlip from one joint fell out on the floor. I think the CV joint was installed wrong. Now I am not sure which way the joint is installed. I think the spring or beveled washer goes on the outside of the joint(toward the wheel) and the clip holds the CV on the axel without a washer. This was how the other axel was. None of my manuals show the detail of the CV assembly. Also, not able to find a source for new Circlips.
Beveled washer goes on the INSIDE of the joint up against the shoulder on the axle itself. PET has a decent exploded view of the components.
One more detail. Which surface of the inner race of the CT joint goes against the spring washer? I assume it is the flat side and not the side with a raised shoulder. And where can I find new Circlips?
Thanks,
