What is a 1982 930 Turbo worth?
Hello everyone, I have a 1982 930 for the last 16 years and I am wondering what it is worth...
I am not looking to sell her, but the car is part of an estate and we are trying to determine what it's value.
it is equipped with the following:
This car is for an enthusiast, and needs minor things to complete which include the following: The interior has all new or newly refurbished parts, the head liner, carpet and dash have been professionally installed. The door panels and other related panel need to be screwed in. Simple to do, and I am sure that I can get more for the car if I did this myself, but I don't have the time. Also, the engine rebuild has about 300 miles on it. At 600 miles you will need to do the valve adjustment and tune the engine, which is standard practice.
It is equipped with the following:
engine was rebuilt by Rennwerke Porsche of Elmsford, and all of the following parts are new (with 300 miles on new rebuild (pistons and rings)
-18 inch Tech Art wheels, ($5,000)
-new, expensive paint (factory paint code U7 Black Metaliic, (similar to to the color of Hematite)
-crank shaft hardened and heat treated by Nascar shop
-all new rubber
-Kokeln intercooler
-K 27 Turbo
-B&B stainless steel headers and heat exchangers
-B&B muffler
-B&B front oil cooler with electronic cooling fan
-Raceware head studs
-ZUCZ EVO air box with K&N air filter
-Andial SC cams
-High tension valve springs
-titanium valve spring retainers
-twin plug heads
-Electromotive twin-plug, crankfired ignition
-Beru spark plugs
-Nology Hotwires
-Andial fuel enrichment controller
-G-50 hydraulic 5 speed transmission with limited slip differential ($7,000)
-Centerforce dual friction clutch
-RSR light weight flywheel
-Carrera chain tensioners
-R 34 A/C upgrade? (I am not sure what it is called
-new head liner
-newly re-leathered front sport seats
-new leather lead liner
-new dash
-new rear deck (designed for optional larger rear speakers (if you know, you know)
-new German wool carpet
-new mirror visors
-new 1983 front valence (for a cleaner look, but I sell have the original one)
Thank you in advance for everyone's input.
-all new rubber
-Kokeln intercooler
-K 27 Turbo
-B&B muffler
-Andial SC cams
-twin plug heads
-Beru spark plugs
-Nology Hotwires
-new head liner
-new dash
-new mirror visors
I just purchased an 84 930 Slant nose (non factory), with a little more engine and tranny work (10,000 miles on rebuild). New suspension, brakes, and tires (stock wheels). Needs some bodywork and a complete paint job. Interior OK, except for seats need recovered. New dash and rear deck. I paid $27,500.
Three months ago, the owner was asking $35,000 and getting offers in the mid 20’s. Most recently he was asking $30,000 and I offered $25,000.
