crazy smoke on boost
Did it once in a while, but now way to often. White smoke like a spy hunter movie. I hope it is the turbo, any sure way to pinpoint?? It is a kokeln turbo. does anyone rebuld them at a fair price?? Thanks in advance
looked at the threads about this still no luck. Intake side dry pressure side dry. turbo shaft has no play.... oil coming from somewhere. Put it all back together no smoke!! errr.. the rubber going to the turbo on the intake side was wet with oil a liltle bit, but no sign in the pipe or the turbo. back to the basics..
I wonder if you don't have a scavenger pump issue, not taking the oil away from the drip pan fast enough, basically flooding your turbo with too much oil and blowing past the seals? There is a ball check valve somewhere in line (I think on the feed to the turbo) that limits how much oil gets to the turbo. Maybe that dude is stuck open since your problem seems intermittent? I don't have enough personal experience in that arena, so just thinking aloud with info from other peoples experiences. Weird.
"under hard boost oil comes out."
That sounds like a clue of some sort. If it's overflowing the drip tank, then maybe too much oil getting to the turbo? Other than scavange pump or check valve issues, how about crankcase ventilation not venting? Long shot maybe...someone out here knows the answer. Come on guys, chime in.
1 Post
On the factory turbo sump tanks a line ran from the tank to the backside of the air cleaner. The sump tank in the picture looks smaller than the B&B style and I suspect the oil may be backing up into the turbocharger. Venting the tank again may help, but enlarging the tank may be a better option.
Worse case, your engine may have excessive blow-by past the piston/rings, creating a smoking situation.
I know that scares the **** out of me.. If the rings were shot would it do it all the time?? The smoke comes and goes.. I am going to mess with the line I capped. You think some one will sell the bigger tank without bying the install kit??? Ill look into that.. thanks werk I
