fuel leak problem.....
ok guys, need some help here.....
The 930 was sitting for about 10 years. Went to a shop to get it running again....cleaned out the tank, new fuel sender, oil return tubes, s-hose, etc, etc. When we ent to pick it up, we started it to warm it up....everything looks good, then shut it down. After chatting for little bit we decide to leave and start it up again and before we take off the mechanic notices there's a drip off of the exhaust. It's gas. We shut it down and he cleans it up. A couple minutes later we start it up and it stopped.
We drove it around and ran some errands watching to see if there was anymore leaks and there were none. A couple days go by and start to take it out and see there's a leak again.
So we take it back and they switch out the #1 injector. Seemed fine at first, but again had a leak later.
So what do you guys think it is? fuel distributor?
Thanks in advance.....
