Where can I get a clutch bracket?
Registered User
Trying to finish my 88 930 trans. PO didn't have an Omega spring on it. Clutch works fine, but I would like to put the proper parts back on. Bought a new omega spring (has the 90 degree bends on the end, not the circular ends), and I noticed that there is nothing to compress it against. Seems that I am missing a bracket.
I have searched through the 930 manual, 101 projects book, and the bentley manual. None show the proper bracket. It looks like what I need is basically a 90 degree bended bracket...looks pretty simple.
All of the books only show the bracket that is side mounted to the trans, intended for the omega spring with the circular ends...
Anyone know the part number of the bracket I need? Anyone have one???
Any help appreciated.
Yep I can help you with this. The part number that you are looking for is 93011671406 it is called the spring hanger and cost on this is $76.32 from Porsche. I think that I have one of these at home I will try to take a look and see tonight. If so I think that we can work something out that would be more reasonable, as you would not believe how small this part is.
Feel free to give me a call later tonight, and I will let you know if I found it.
Happy to help,
Erik Johnson
GBox Performance Transaxle
(303) 440-8899 work
(303) 895-4828 cell
www.gboxweb.com
Happy to help,
Erik Johnson
(303) 440-8899 work
(303) 895-4828 cell
www.gboxweb.com
