pedal box and 930 four speed shift knob
Need to purchase a pedal box out of a 1986, 87 or 88 1930 Turbo....must be complete with clutch shaft and would like the 930.423.005.00 spring.....one with turn buckle so it can be tightened after installed. Also...need a nice shifter **** for a 930 transmission. This is the pear shaped...leather covered **** with the snap ..or pry...off plastic cover with the shift pattern on it....**** is held on by a allen drive bolt that you get to by removing the plastic cover. The leather on mine is worn thru in spots after 240,000 miles worth of shifting. Please email me at "budgetmh@bellsouth.net" Thanks..
