Do these oil cooler vents really work?
Yes, the fan is on the oil cooler located in front of the right front wheel. 250* is WAY too hot. You are cooking your oil. The fan should come on at about 230*, which is hot for me. Mine runs about 200-210* around town. 212* is actually good to burn off any condensation.
Do you have a stock temp gauge or a numerical gauge? On a stock guage, the 9 o'clock position is 212*.
Thanks for the help.
You can unplug the fan and apply power to it to see if it's good. Then you'll need to check the other items mentioned. A new fan is crazy money ($350?) which is why I mentioned a fan from Jegs or Summit.
You may also want to check you oil thermostat in the right rear wheel well. If it's not opening all the way, it won't cool very well. I think DonE posted here (or Pelican) recently about it.
http://forums.pelicanparts.com/showthread.php?t=491680
I wonder if my oil thermostat is stuck wide open, or gauge calibration issues. Guess I'll drop a thermocouple down into the oil tank next time she's nice and warm as see what the actual temp is.
My fan actually came on today after I played with the connections. I'm guessing they were a bit oxidized from sitting for so long. I got stuck in construction and the highest I saw the temp go was about 230-240. I think I'd like to see the fan come on around 220, instead of 235 though.
So true. I read his comment to mean that 240 is atypical, not necessarily injurious. I would be more concerned with EGT's getting up there commensurate with oil temps, and coking in the turbo.
I saw these on ebay and thought they looked like a neat idea, but I'm curious if they really do anything other than ridding me of $95: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT My temp usually hangs around 240* after it's warmed up.
