Smoke on start up???
Hey forum,
I recently overfilled my engine oil by a quart as I noticed that it would give a puff of white smoke on start up. It does not puff smoke any other time, just on start up after the car sits for several hours. I removed almost a quart and checked the level and it is now at the proper level. The smoke is still there on start up??? Will this go away or is there something that I need to do to get it to stop doing this? Any help is appreciated. Thanks folks!
You did check ithe level while it was warm and running, correct? Keep it halfway between the marks.
The next thing is to remove, check and clean your air cleaner, intercooler, muffler, etc. Any where that oil could have gotten into. I used Dawn dishwashing soap years ago when I overfilled mine.
Funny, I overfilled mine just last week by a good quart+ and didn't have any issues. Ran it until hot, checked the oil level, said "oh $hit!!", let her cool down and drained off about a quart. She's still at the top of the dipstick mark but not smokin'.
1 Post
Trust me when I agree with Rocket, drain it to the half way mark or pay the price. I left drips every where I went and everything in the engine bay was covered with a film of oil. It has no where to go except out the top end. That would be through the IC and everything that the intake air goes through. If you are unlucky enough to have replaced the OEM air filter with a simple air filter and several small hose filters, you will have a bigger mess to clean up.
If you look at the oil tank filler tube, you can see a hose running from it to the air cleaner. Oil is sucked out of the tank into the housing/engine. It soaks the air cleaner, drips out the bottom of the air cleaner housing, is sucked into the intake, where it gets into the IC, then goes into the cylinders. What isn't burned then goes into the muffler where it does a slow but heavy smoke screen for days until it burns off. BTDT.
So far, no drips no smoke no symptoms of overfull. But I really don't want to wait for them to occur when all it takes is a couple of minutes and some rags....
It doesn't have to be hot. Your only trying to drain half a quart. Unscrew and hold the drain plug at the drain and just let it stream out slowly.
Since it's not hot. you won't drop the plug and lose all your all.
About hot, I was just being facetious. And I'm happy to report that I drained out about 3/4 qt. without spilling a drop....well, except for coating my entire hand. But I kept it off the garage floor. Gives me a reason to drive her tomorrow!
1 Post
The oil tube that goes to the intake from the oil tank is so the oil vapor will be burned in the engine and not vented to the atmosphere. People that remove the OEM intake don't have anywhere to run the hose so they put little filters on the end of the hose. The oil vapor is trapped in the filter for a while but eventually will seep out into the engine bay. Here is how I and others have combined a new freer flowing filter but retain the oil hose hook up.
1 Post
You can see one of the small lines directly under the narrow part of the intake housing. There is also one that you can't see on the back side of the same housing.
