High Standard 934 Project ***Make me an Offer***
Entire Project for less than what I just paid for the motor! Everything is located at Fat Cat Fabrication in Buford, GA (www.fatcatfabrication.com) and Chad Ernst will be glad to finish this project for the new owner. Economic conditions are forcing liquidation, someone is going to save a LOT of money and time!
I was asking $49K
Build Progress:
http://forums.pelicanparts.com/showt...ht=934+project
http://forums.pelicanparts.com/showt...42#post3996342
http://forums.pelicanparts.com/showthread.php?t=427376
http://forums.pelicanparts.com/showthread.php?t=433248
Project consists of the following and what I have spent so far:
1986 930 Turbo Street Car with 103,000 miles and minor body damage: $13,000.00
Rudtner's Racing 3.4L Turbo Race Motor: $50,842.22 (includes 12 month warranty) Motor still in the crate as delivered from Bill Rudtner
* Modified Crankshaft (2" journals, oiling modifications)
* Shuffle Pinned Case
* Boattailed Mains
* GT3R Oil Pump
* Pauter Rods
* Coated JE Pistons
* Perfect Bore Cylinders
* AASCO Springs
* Titanium Retainers
* Web Cams
* Mode Individual Throttle Bodies (Bob Holcombe)
* Ported Carrera Heads
* Large Custom Intercooler
* 1.75" B&B Header
* Precision Turbo 7076H (820HP)
* Programmed Haltech ECU (Motor tuned on dyno in Bill's 935)
* Individual Coil Packs
* 500+RWHP @ .8BAR
930 Turbo 4-Speed Transaxle: $5238.31
* Completely freshened and re-geared
* Stock 1st
* 2nd: 18:26 (1.44:1)
* 3rd: 26:27 (1.04:1)
* 4th: 29:23 (.79:1)
* Factory LSD
Rennsport Systems Suspension: $13076.85
* Front Camber boxes with camber plates
* Rear Camber boxes
* Moton double adjustable remote reservoir struts and shocks
* Bilstein spindles for Motons
* ERP 935 front suspension system
* ERP 935 rear spring plates
* ERP bump steer kit
* Smart Racing front and rear 23mm adjustable sway bars
* H&R springs 400F and 600R with tenders and separators
Rennsport Systems Fuel Cell and Oil Tank: $3859.85
* 27G Fuel Safe fuel cell with dual pickups/center fill
* Smart Racing Products front mount oil tank
AIR 934 Bodywork: $1000.00
Getty Design Carbon Fiber Dash: $700.00
CCW Wheels: $2500.00
* 18x10 Front
* 18x13 Rear
Dis-assembly and Stripping: $3000.00
Frame check: $755.00
Lexan Windshield, Qtrs, Rear Window: $1500.00
Fat Cat Fabrication: $5000.00+
Please call to discuss,
Cleve Meredith
404-226-9766
clevejr@gmail.com
I was asking $49K
Build Progress:
* Boattailed Mains
* GT3R Oil Pump
* Pauter Rods
* Coated JE Pistons
* AASCO Springs
* Web Cams
* 1.75" B&B Header
* 500+RWHP @ .8BAR
* Stock 1st
* Factory LSD
* Rear Camber boxes
* 18x10 Front
* 18x13 Rear
Cleve Meredith
404-226-9766
clevejr@gmail.com
934, 935, bob, cat, design, discussion, fabrication, fat, getty, high, holcombe, intercooler, parts, pelican, pelicanpartscom930turbo, standard
