if I put a manual boost control how do I set it?& where to get 0.9 spring
if I put a manual boost control how do I set it to givr me 0.9 bar can I use the stock guage to set or I will need and aftermarket. should I just purchase a 0.9 spring? if so where do I purchase one?
thanks
thanks
I don't know all the particulars, but you do have to use a lower rated spring like .5 bar to start with. This will be your starting point. From here you adjust it up until you blow the engine up. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Definately use an aftermarket boost gauge. The stock one is worthless.
1 Post
With any boost controller you can only go as low as the WG spring is rated for,i.e. .8 OEM will give you .8 as your lowest boost. I have a two position boost controller and the two settings are, .8 and .98. with a switch inside to select either one. Your engine should be in good shape to use any BC and higher boost should be used infrenquently if at all.
