993 heat exchanger project
Well after a lot of thought I embarked a project which I hope was worth while. this is a mix between stock 993 heat exchangers and my fabbed 321 stainless y. Any thoughts? This was designed with thought of how not to have it crack.
My thoughts:
Pros
- should have oem durability
- twin wastegate design should eliminate overboost situations
- short runs to turbo should help to reduce lag
- gorgeous welds...(these are brought to us by Ben at M&K)
- good pricing as reflected on the "other" forum
Cons
- less than ideal collector design.
- large primary size may reduce exhaust gas velocity
I think they look great. Cannot wait to see the dyno results from rarlyl8.
JP
Pros
Cons
JP
Last edited by rsrfan; 01-19-2009 at 09:35 PM. Reason: correct my horrendous spelling
interestingly the collector is much better viewed from the inside. it is way better and evenly split then it appears. thank you for your suggestions though and feedback
