Alternator????
I am looking into buying an alternator and i notice the c2turbo alternators are diffrent. They are 115amp compared to the 930 90amp and they are about $200 compared to the 930 $330. So i been leaning toward getting the c2turbo alternator for obvious reasons. But my question is, will it fit? if not, anythign i can do to make it fit? what is the diffrence.
thanks in advance
thanks in advance
Why do you need the higher output? The stock one works fine, but to answer your question, it might not. looking at oictures, the C2 alternator has 4 bolts vs the 930 having 6 bolts. The shaft appears longer on the C2 as well.
Pelican carries a high output 95 amp alternator, but doesn't list the stock one.
Stock on the top left. High output on the top right.
C2T Alternator on the bottom left.
I agree I don't think they are compatible. The C2 s designed to use the 2 pulley/belt system. The alternator and fan spin at different speeds one runs directly off the crank while the other is driven by the A/C belt using different pulley dia. The 930s had a single belt design where the fan and alternator spin at engine speed. This would require making serious and expensive mods to work, if it can even be done.
