911 Turbo (930) Forum 1975-1989
Leask RPM Activated Fuel Enrichment Kit For Sale
Old 10-16-2008, 01:21 PM
early85944
early85944's Avatar
Default Leask RPM Activated Fuel Enrichment Kit For Sale
Just as the title says. The enrichment kit is brand new. I paid $200 for it. I will sell it for $150 if anyone is intrested. It comes with everything you need including instructions. If you have the WUR but not the RPM activated switch here is a great chance to get it. I am parting with the car so there is no need for it.
Old 10-16-2008, 03:00 PM
nathanUK '81 930 G50
nathanUK '81 930 G50's Avatar
Would that also include the solenoid valve it operates?
Old 10-16-2008, 04:10 PM
early85944
early85944's Avatar
yes it does include the valve as well
Old 10-17-2008, 02:40 PM
Hopefully someone needs it!
Old 10-17-2008, 03:35 PM
F350Lawman
F350Lawman's Avatar
I have one and it works real well, you can set things rich on boost and then hold off the fuel dump until you really need....it at th higher RPMs. makes tuning easier.
Old 10-18-2008, 12:23 AM
A930Rocket
A930Rocket's Avatar
So with this you need Brian's modified WUR as well correct?
Did he ever come out with a digital WUR?
Old 10-18-2008, 02:09 AM
Chuck Jones
Chuck Jones's Avatar
No...Brian's WUR is mechanically adjustable...but it works well for me.
Old 10-18-2008, 04:46 AM
The solenoid kit can be fitted to any WUR.
I haven't heard of him releasing a DWUR yet.
Old 10-18-2008, 06:17 PM
A930Rocket
A930Rocket's Avatar
Im interested in it, but want to make sure this is all I will need to add to my current stock WUR.
Anything else I need to add to make it work?
Old 10-18-2008, 09:33 PM
Mark Houghton
Mark Houghton's Avatar
PM sent.
Old 10-19-2008, 05:25 AM
Rocket, do you get too rich as soon as you get on boost and then it flattens out correctly?
What ignition are you running?
Old 10-19-2008, 04:45 PM
A930Rocket
A930Rocket's Avatar
I'm using the MSD6AL. On track, when I get on the boost, the AF gauge goes rich and then leans out to about 12.5 (at top end of 3rd gear). I'd like to get rid of that fat period when I floor it.
Old 10-20-2008, 03:03 PM
Sounds like you could benefit from delayed enrichment.
You should ask Brian Leask if it will work with the MSD though.
Old 10-20-2008, 04:08 PM
JBrown
JBrown's Avatar
A930Rocket, The soliniod will work but the MSD box you are going to get with it will not. It will not work with a distributor less ignition. You need a different MSD trigger box. I think the model # is 6989. If you are running rich in midrange you will LOVE the soliniod set up. I drop into the 9's without the soliniod. When I hook it up I drop down into the low 11's then it climbs to about 12.2 at 4800 rpms, Then the soliniod opens up and drops me back down to low 11's till redline 12.5.
Old 10-20-2008, 06:16 PM
early85944
early85944's Avatar
Sold thanks for all of the intrest
Quick Reply: Leask RPM Activated Fuel Enrichment Kit For Sale
