Help to find a 78-81 Porsche 930
Ryan its black on black. Body was media blasted to the metal then epoxy primered painted to orignal black as a single stage. The engine was in a box in pieces found it had three bent valves- could not get any info from owner on how it happened beening he was dead. resealed engine replaced rings etc. trans found no metal in fluid so just replace all seals in it. i have run engine on stand to make sure no leaks or problems before in install it in car, should have body back tommorow - interior is in great shape the only flaw is were the previous owner installed after market alarm and drilled hole in dash next to ignition switch - i have a upholstry guy going to fix since i can not find a replacement piece. but all rubber is new door windows etc. with factory parts
probley have 15k in parts not including labor or body shop. Let me know if you are intrested do have several people asking about it also i'm looking in about 30 days or less to be ready for sale.
