Straight pipe on my euro 930?
I'm considering swapping my Fabspeed muffler for a straight open pipe exhaust. Anybody have any thoughts or experiences?
I'm not sure if it will be too radical for street use I don't track the car.
For what it's worth, has anybody dealt with Brian Bodart at RarlyL8.com ?
Brian is good to deal with and has been on here and the other boards for a long time, though he still praises CIS his exhaust pieces works well. I suggest doing a search.
i just made the same conversion that you are contemplating. it is not loud...it is LOUD!!!
i will be fabricating a system with a 14" borla 3"i.d. bullet as my noise supression. i think it will still be liud but it will take the edge off. the straight tube exhaust sounds pretty shabby at idle and off idle. takes a while before it sounds good...but it does sound good up in the rev range!!!
Pete, standing on the gas must sound pretty wild but I guess I don't want a cheesey sound at idle. Brian Bodart has another version of the straight pipe which has a hollow muffler instead of the straight through pipe. That might clean up the idle a bit which I think is also what you're trying to achieve. Did you get any flames on decelleration? Are you able to hear your turbo spool? I didn't hear it in the video.
I have purchased a couple of different pieces from Brian and the construction is top notch. Brian is really great to work with. He is actually working on a really cool custom setup for me right now. He has gone out of his way to come up with a solution that will fit my exact needs.
Oh and the Zork is REALLY LOUD. I love it but know I am going to get black flagged at certain tracks so I will be running an alternative muffler set up on occasion.
930LDR,
What are you getting built? Brian suggested that if I wanted loud that he would build me a straight pipe, similiar to the zork but longer exiting on the pass side and a waste gate pipe on the drivers side but after hearing from some of the forum guys it might be a bettter idea to use his muffler style pipe but hollow. What do you think? It would be cool to have one of each so I can listen to them and compare. I wonder if he'll give me a deal on both considering I'll only be using one of them? Ya right! I have to talk to him.
Thanks for the props, appreciate it.
I can build both versions of the passenger's side outlet muffler/zork using the same jig; so yes there can be a significant savings when ordering both.
My Rennlist membership ran out 10 years ago so I shouldn't be talking shop on this forum. Shoot me an e-mail or phone call.
Thanks.
Thanks.
I recently like Pete added a straight Zork pipe off the turbo. There is a thread -"Cut the zork stinger and added stainless wastegate pipe- like we debated" on it.
The car sounds increadable and under load has a distinct turbo hiss. If you low RPM it you can quitely drive but under WOT it sounds like a F1 car. Not for the faint of heart. The turbo does muffle the sound some, I cannot imagine the car being black flagged, but who knows
Here is what mine started out as after we welded on a chrome tip, and what the car looked like after we cut 5" off tip and added the modified valance.. Good Luck, Mike
![](http://forums.rennlist.com/upload/dec2007_002a.jpg)
![](http://forums.rennlist.com/upload/jan2008_lake_sized1.jpg)
![](http://forums.rennlist.com/upload/jan2008_012sized.jpg)
Thanks.
Thanks.
What kinda deal can you offer me for both pipes as well as the waste gate pipe? PM me if you have to.
Rob
