Installing K27 problems...
Well I got my K27 and (used) BB exhaust bolted up.
I thought I was ready to put the intercooler on then I think I found something I screwed up..
The turbo isn't centered in the cut out. So the billet adapter doesn't seat all the way down. You can see a 1/4" gap in this picture. I just wanted to confirm this will screw up the intercooler before taking the turbo back out and making that hole bigger...
Just fired up to check for leaks etc. I was surprised how tame the B&B muffler sounds. Has a nice back rap but not much louder. I think I will try a 4" muffler next..
It looks like you have the B&B 4" dual outlet muffler already. It's just the tips that are 4" the pipe is still 3" or whatever it is.
I have the B&B 4" single out muffler and the sound level is perfect for my tastes.
If you look inside there is not much in there to restrict the exhaust
I am not sure what is inside the muffler (didn't really look). What I think I will try though is a 4" straight pipe from the turbo existing on the passenger side. Hopefully it would be quiter then a zork but louder then what I have.
I have another issue with putting the intercooler back.. (cross post )
Ok here is what I am dealing with:
this is the driver side. I think it is on correct.
Passenger Side:
They Extra Parts-I thought these were used to bolt down the passenger side but don't see how it can now.
Extra Candy (My copycat rarly8 air cleaner)
Passenger Side:
1 Post
Passenger Side:
Passenger Side:
I am running one of those new $$ Zero clearance hybrid Garretts on my old Turbo Z and I just re-clocked it using David (125 Shifter) suggestion.
Yasin
