Best Way To Jack Up The Front?
The safest way is to jack one side up and then the other using the jack points behind the front wheels. Any other technique like using a piece of plywood behind the lower A/C cond. is risky plus you have to have a long nose low floor jack.
There is a rub bar under the front end that you can use to raise the nose, but you've got to be sure you only have pressure on that bar and nothing else. Otherwise it'll take out the cooler and a bunch of sheet metal. Until someone with a lot of experience jacking it from the front shows you how its done, I'd stick with the lifting each side. as Rudy said above.
If you use the front jack points to jack it up, how do you get the jack stand on the same point?
On the 964, we use the REAR jack point, which raises the front and rear. We then put the jack stands under the front jack point. To jack up on all four, we then jack under the engine so we can put jack stands under the rear jack points.
Dude...
Simplist is one side at a time at the forward suspension mounting point on each side. Some cars have a loop attached to the rounded cover that hides the center of the 3 bolts that attach to the pan.
And NO it will not bend the pan, control arm or pull suspension out of line!
Once up, you should see the area either behind the wheel or usethe area close to the jack (yes on the a arm to put your jack stands.
P-
P-
I place my jackstands under the front control arms or torsion tube. That jack pad is pretty small to me to place a jackstand and then get under the car.
He was asking about the front though. Using the rear jack pad works as well. Just need to jack it up more.
I use the jack points behind the front wheels to jack the car up and then put the jack stand on the rear attach point of the A arm. If you have the V shaped jack stand mounts you can use either end of the arm tube as close to the mounting point as possible. I strongly do NOT recommend using the front condensor protection guard bar. The bar itself will hold the car ok, but the ends of the bar are squeezed flat to accomadate bolts and that is where it looses a lot of its strength. Any part of the car that normally supports the cars weight is a good spot to put the stands. Be careful though because these cars can be moved while up on stands with some aggressive wrench turning or pulling. NEVER get under your car without at least putting a stand under it next to your head, even if it doesn't actually support the car at that moment. I knew a pilot who was working on his car in his driveway using concrete blocks as stands that failed, and he is still in a wheel chair today, (30 years later). Figure the cost of something like that versus $1200 or less for a scissor lift and it doesn't seem like a choice at all.
