Sc-cams
Sc-cams
I just woundring Sc-cams how big Hp and torque do the handle???I have it mine 930 turbo and i want more hp but i dont know how musch more the can take....I have right now onlye 360 hp...
Thx
PimPim
Thx
PimPim
I've had SC cams handle right at 400rwhp on my car, but that was with lots of modifications. There are two things important to cams on a Porsche forced induction system - cam timing and cam synch (side to side). I advanced my cams quite a bit to get the turbo spinning and they worked well. I then went to 964 cams which gave me more top end, but not a lot more. Now with EFI, I run GTII cams.
By the way, 360 hp is very respectable.
And that's 20 hours if you don't get caught up in "While I'm in there..." Ask me how I know. I'm doing a cam replacement right now and I am just doing the little things that need to be done to correct previous mistakes. It's a good thing I like playing with this car, cause I'm doing a lot of it!
I'm finding there are all sorts of custom cam grinds available for our 930 breed. If I had more time I'd love to chart the various versions I've found. Still haven't decided which is best for me yet though.
FWIW, I found this excellent explanation helpful in my understanding of the process:
http://www.compcams.com/Technical/TimingTutorial/
Cheers!
Cheers!
I know I've asked about this before, but when the SC cams go in, are there any other changes needed? I ask because I have never gotten my car to run right, and I have SC cams set at 1.6 on both banks of cylinders. Lots of power and smooth over 3,000 rpm, balky and inefficient (low mpg) below 3,000. I see boost before 2,500. I am planning to go back to stock cams this winter. My basic problem is that my car (77 3.0) ran badly, and had a worn turbo, when I bought it, so I don't have good baseline for comparison.
Of course, I've spent lots of time trying to find the usual suspects, e.g., vacuum leaks, fuel pressure issues and ignition timing, without finding the culprit for my running issues, hence the hunch that it is the cams.
ok guys need some advice 85 930 kokeln IC and street turbo with b & b full exhaust. motor is out thinking of SC cams whats your opinions how much more hp gain how much should I pay for them and does anyone have a set or where can I get them? also does anyone suggest a diff. cam? thanks in advance.
