retorque head studs?
when i redid my engine I installed raceware head studs and nuts do they need to be retorqued later? i didnt do it the other day when I did the first post rebuild valve adjustment, does it need to be done next time i do the valves?
I use ARP. According to them, if you condition the nut with the stud and torque it using their lube, you will not need to re-torque. So, on my second rebuild, while I had the motor dropped to adjust valves, I checked 4-5-6 and all were in spec as promised. I guess if you're in there to adjust valve lash, you might as well check 'em.
mine are not arp they are race ware when i bought and installed them a couple years ago i didnt know the difference between the two. the rod bolts are arp but not the head studs
