Billet Design's throttle body adapter...
A while back, (3 yrs ago now) I bought Marco's adapter plate that allows you to bolt an aftermarket throttle body (normally for a Mustang) to the 3.2 intake.
Does anyone recall which throttle bodies work with this plate???
I'm probably going to get an AccuFab unit...
Unless you guys have other suggestions...
My current 3.2 throttle body, the spring that wraps around the throttle plate shaft is broken, so I am snapping throttle return springs on the track (makes for an un-easy feeling)...
Brian
Brian
Rocket:
The the larger TB is one option, I think the other option is being able to install another brand/make of throttle body that is readily available, whereas the stock 3.2 TB's are getting hard to locate (most people want to sell them with the intake).
So to me, that's the big thing, it creates "availability" of spare parts...
Brian
Brian
Originally Posted by BrianKeithSmith
Thanks Don. You wouldn't happen to have a Part Number would ya?
Besides being cheaper, they are extremely easy to hook up with the stock bellcrank.
Pic would be nice if you've got one.
I don't use the stock bellcrank. I have a custom cable running through the cockpit to the engine bay. It should still be pretty easy to hook up though....
If you've got a pic, I'd appreciate it Don.
Thanks,
Brian
Thanks,
Brian
